Buyiing mwb glx transit
Postby Mossy » Sun Nov 28, 2010 6:41 pm
Hi All
Went to look at a 56 plate glx 110 mwb transit yesterday. all seems good with the spec i was looking for. Only question is what sort of performance should i expect as the test drive didnt blow me away. I have driven 08 plate 115 trannies and they fly from rest. Obviousley im not looking for the van for a performance vehicle but when i accelerated in the 110 it wasnt the same go. The van has 72000 miles on it, a new egr valve, also the accelerator seemed on or off. Not much feel and progression on the peddle movement.
i have heard the set up can be changed by ford on the accelerator is this true due to the drive by wire set up. Going back tomorrow to have another test drive but any feedback is much appreciated
Mossy
Re: Buyiing mwb glx transit
Postby Luke » Sun Nov 28, 2010 7:00 pm
theres a difference in the fwd and rwd transits - were the both the same you've driven :?: :D
Postby AndyG » Sun Nov 28, 2010 7:59 pm
You really need axle ratios to diff :P erentiate between these Transits :!:
They all have turbos, so I would expect them all to fly :!:
Post the registrations up or enter the registrations into ETIS :idea:
Postby Mossy » Sun Nov 28, 2010 9:07 pm
yep both were fwd that i drove, 110s and then the 115 was a rear wheel drive hire van with the 6 speed box.
reg is yh56 bcy of the van that i am looking at.
cheers for replies so far
Mossy
Postby AndyG » Mon Nov 29, 2010 12:36 am
So to compare, we need to know what the other van is
Transit (V347/348), 2.2L Duratorq-TDCi (110PS) - Puma, Frozen White
VIN Number: WF0XXXBDFX6B51002
Registration Number: YH56BCY
Registration Date: 27.10.2006
Registration Country: GB
Primary Features
Build Date: 21.09.2006
Vehicle Line: Transit (V347/348)
Cab Style: Regular Cargo Van
Series: 280M Series
Engine: 2.2L Duratorq-TDCi (110PS) - Puma
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.23
Emission: Stage IV Emissions
Air Conditioning: Manual Air Conditioning
Territory: (+)"GB"
Paint: Frozen White
Interior Fabric: Tomy (G-C)
[Click to collapse]
Minor Features
* With Medium Roof
* With Rear Mudflaps
* High Door Height
* With Full Partition - Steel
* Southampton Plant Built
* Marketing Flex Prep Pack 2
* GLX Sales Badge
* Less SVO Application/Label
* Less Trim Pack
* With Power Equipment Group
* Marketing Level 3
* With Visibility Pack
* European Environmental Label
* With Power Front Windows
* With All Light Tinted Glass
* Less 2nd Row RH Side Window
* With Rear Blanking Panel
* With Heated Windscreen
* Less Heated Rear Window
* Less Rear Compartment Trim Panel
* With Bright Air Vent Knob
* With Front Roof Grab Handle
* With Load Space Tie Down Loop
* Less Rear Window Protector
* Less Rear View Mirror
* Large Head/Short Arm Mirror
* With Drivers Seat Fixed Armrest
* Less Passenger Seat Armrests
* Less Passenger Seat Valance
* Less Seat/Airbag Pack
* Less Temp Control Driver Seat
* Less Temp Control Passengers Seat
* Less 2nd Row Rear Seat
* With Driver 6 Way Mnl.Seat Adjuster
* Less Adjustable Passenger Seat
* Less Rear Seat Armrest Packs
* With Front Towing Hook
* With Door Dead Locks
* Less Side/Rr Door Security Lockset
* Remote Control Door Entry - 2 Fob
* Less Rear Window Wiper/Washer
* Rain Sensor - Fr Windscreen Wiper
* Front Bumper Body Coloured Plastic
* Less Rear Seat Belts
* Less Passenger Air Bag
* Less Float Mounting
* With Spare Tyre Security Package
* With Full Wheel Cover
* Less Diesel Fuel Cooler
* Cold Start Up To -20%c
* With Tunnel Mounted Parking Brake
* Power 4-Wheel Disc Vacuum Boost
* 4 Wheel Anti-Lock Braking System
* With Brake Only Traction Control
* Less Transfer Case
* With Sngle.L/B Dvr/Dual L/B Pass.St
* Less A/C Unit - Roof Mounted
* With Recirculating Heater
* Fuel Water Separator Less Sensor
* Less Auxiliary Heater
* With MPH/KMH Speedo
* With Trip Computer
* With Radio Pre-Equipment Pack 1
* High CDX6+AM/FM Radio W/Diversity
* Ice Feature Pack 7
* Less Telephone Preparation Pack
* With Column Stalk Radio Controls
* Less Smokers Package
* Less Optional Equipment Pack
* With Front Fog Lamps
* With High Mounted Stop Lamp
* With Manual Headlamp Levelling
* With Automatic Headlamp On/Off
* Less Battery Cut Off Relay
* Less Roof Flasher Wiring
* Less Auxiliary Fuse Panel
Return to Buyers Guide
