Hi Guys,
I'm going to look at a Mk6 2001 RWD LWB 350/90 Transit tomorrow. It will be my first Transit so just looking for a few tips.
I've had a search on the site and I think the VIN number should be in the Windscreen, N/S door shut and O/S/F Inner Wing. The Engine number should be by the rear right hand side of the cylinder block, by the oil sump flange, and also is located on the right hand side of the cylinder head above the exhaust manifold. Is this everywhere I need to look to check all the numbers?
Also are there any common faults or expensive repair jobs I should be looking for? The van has got 80k miles on the clock at the moment.
Cheers,
Martin
