Baddest Van Alive
Baddest Van Alive
Postby vidma&tas » Wed Aug 07, 2013 11:55 pm
Not bad meaning bad, but bad meaning good = ]
vidma&tas
Re: Baddest Van Alive
Postby pat stevens » Sat Aug 10, 2013 8:33 pm
very nice looks like itll turn into a cool van :D :D :D
if its got tits or wheels its always gonna end in trouble !!!
anyone can restore a van but it takes a real man to chop it up !!!
pat stevens
Postby vidma&tas » Mon Aug 12, 2013 7:25 pm
vidma&tas
Postby Luke » Mon Aug 12, 2013 8:51 pm
8) 8)
Postby ColinJack » Tue Aug 13, 2013 10:58 pm
Nice wheels. Just need to flare the arches a little. Going to be a mean looking van when finished. What you got under the bonnet?
1989 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Postby spinna » Wed Aug 14, 2013 7:36 am
Be nice to see when painted
2009 MK7 T330, 2.4TDCI 100 SWB.
1994 Nissan Patrol Y60 4.2 diesel
2004 Vauxhall Vectra SRi 1.9cdti
spinna
Postby vidma&tas » Mon Aug 26, 2013 7:54 am
Done something in past weeks, couple more years and will be perfect = ]
For now ugly greasy 2.9 cologne running on carb and 2,3 oil pump with distrib = ] , electric pump always overflows carb, made one line back to tank, but needs regulator or another pump, bit exhausting as same problems again and again.... especially as planinig to put 24V later on.
T9 box with huge shifter spacer, shifts quite well and dont hit feet.
Arches will be as is now, later maybe with 215 insted now 235-255.
Rear arches done to mach front, and I believe flairing front would be very difficult, as part wich meet doors are to firm. and wheels for now stands perfect, not acourding to mot, but will leave this one to sort later.
vidma&tas
Postby vidma&tas » Mon Aug 26, 2013 9:39 am
forgot to put lights in = ]
vidma&tas
Postby ColinJack » Mon Aug 26, 2013 11:30 am
Custard Cream! :lol:
Looking good ...
ColinJack
Postby bortaf » Mon Aug 26, 2013 2:13 pm
Thats does look nice 8)
What fuel pump are you running? most need a regulator to lower the pressure except one of those noisy solid state ones, if the float valve is sealing propperly and the return line is clear then TBH even running a few PSi over the recomended 3 PSi will be ok but much over 5 will push fuel past the valve even with a return line IME.
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby BigMonty » Mon Aug 26, 2013 6:41 pm
8) awsome 8)
BigMonty
Postby vidma&tas » Tue Aug 27, 2013 8:41 am
"push fuel past the valve "
that exact thing happend to last carb, needle goes sidways and dont return to normal position then I need to open top, put needle properly and wait till next time, changed carb to another one, for now it doesnt overflow, but near death seals die faster with high press pump = [
pump is noisy from 2.9 12v scorpio, as autodata says - around 3 bar pressure...
line into carb - 6mm, and in that line from pump to carb 3way nipple with 4mm line back to tank. Have couple regulators, but it seems that function scale on these are higher (on top and bottom possitions it does not affect owerflow), and it does not stop problem. Maybe it occures as needle once was damaged never funcions properly?
Looking for another pump, or any other fast repair?
Joy ride coused to hit arches = [ needs flairing afterall or just bigger bumpstops.
vidma&tas
Postby malta transit » Tue Aug 27, 2013 10:45 pm
Very Cooooooool!!!!!!! I Love it :D
malta transit
Our man in Malta!
Postby vidma&tas » Thu Aug 29, 2013 10:28 am
So found 0.2bar fuel pump, hope that will be good.
Quick q: wiper arms both same?
What is length of both wipers for original arms? 55cm?
vidma&tas
Postby vidma&tas » Wed Sep 04, 2013 5:57 pm
Done first longer run with this Baby.
Sick acceleration, for Me it fells like drag tractor = ] throttle more on-off type at pedal top, so shift change results noisy body displasment (?) Some seems welded. Or it's just becouse most doors don't have seals..
Seems to be accepting all transplants well , sadly MOT has different opinion.
Strange and fast Van on a way!
vidma&tas
