Nel5on wrote:Single wheel.
And that another problem....
Tyres seem to chafe on rim edges, on long trips, running 8ply tyres
Nel5on
FredTransit wrote:Nel5on wrote:Single wheel.
Nel5on
This sounds like a tracking problem, at least with the single wheel any tyre place should be able to fix it, TW are more difficult (so I am told, but others seem to use this as an excuse not to have to do it!)
Luke wrote:just googled this!1.8 TDI 1753cc 16V Diesel 65KW (88PS) at 4500 RPM
out of a mk1 mondeo! are they 16vnot 100% sure its the right engine!!
I was also thinking about a zetec for mine but was put off by the fact that they are designed around fwd in the layout and when there fitted in the mk1&2 escorts you have to alter the pipework or cut the bulkhead away!! still possable and getting one is cheep enough, good engine!!!Nel5on wrote:If i had a good type9, the zetec would be the best way to go. Are these engine easy to re loom?
