generator
generator
Postby geomorri » Sun Nov 20, 2005 7:31 pm
Hi I've recently just bought a P reg tranny and I've noticed it used to be an old waterboard van. It used to be fitted with a generator to power the power points inside but someone has had it away and I'm wondering if anyone knows where to get one from, the generator was driven by a pto which is still there.The van also has two batteries fitted and the extra battery seems to link to some sort of control box if anyone has any ideas? :?
geomorri
Postby Nighthawk » Sun Nov 20, 2005 9:06 pm
Your going to need to check the vehicle for labels from the original equipment installers.
Transit's of that era never had an SVO option for power take off.
How's yours done......off the propshaft?
A popular fittment on transco vehicles was done by a company called stallion.
Maybe the control box has a phone number on.
An easier way of providing AC mains power on a vehicle would be to use an inverter.
Nighthawk
Postby stevew » Mon Nov 21, 2005 12:34 pm
Yep I'm with Nighthawk on this one. Modified sine wave inverters are getting so cheap it's almost a waste not having one! However that's only true up to around 500W. If you need lots of power then inverters get expensive and generators start to look more attractive. Also if you fit a 2kW inverter and try to run it from a 'normal' size battery, say 100Ah, it'll probably only last 15 minutes :shock: at full load.
As for your control box, twin batteries can be arranged differently deppending on what they were used for. Some are just wired in parallel to get more starting power on cold mornings. Others, as yours seems to be, are wired as seperate batteries, one for starting the vehicle and the other for running equipment when the engine is stopped. The batteries are disconected from each other when the engine isn't running so that you can't flatten the starter battery with your lights/inverter or whatever and you can't try to start from the auxilliary battery which may not be rated for starting current. It sounds like your box is such a seperating device. Normally this is done with either a simple relay, large enough for the current, or a set of diodes. More complex and expensive systems exist though.
Steve
stevew
