Mk7 2.4 115 rwd tipper abs problems
Postby Chassiscabdave » Mon Feb 11, 2019 9:27 pm
Hi everyone, I have a 2009 transit double cab tipper which has had nothing but issues since I got it 3 months ago, the newest one on the list is that the abs light, traction control light and handbrake light are on, I had it plugged in and changed the rear abs sensor, now it has fault code c1a76-14 valve relay. All relays are fine, what now
Chassiscabdave
Re: Mk7 2.4 115 rwd tipper abs problems
Postby loot » Mon Feb 11, 2019 10:37 pm
Found this on Google
Broken loom from fuse 26 under bonnet fuse box to pin 3 at the abs module.
Probably a com wrote at the abs module, maybe ids and live data can help narrow it down more?
07 350 170ps
Ids map here
loot
Postby Chassiscabdave » Mon Feb 11, 2019 11:06 pm
Ok thanks, I will relay this to my mechanic, I think it’s defo electrical fault but don’t have the patients to do it myself, I’m more of a bolt on bob, also It’s got starting issues this week too, money pit
Chassiscabdave
Users browsing this forum: GuyT
