Raising MK7 Rear Suspension
Postby stucos71 » Sun Apr 14, 2019 6:57 pm
Hi,
I’m having a bit of a time with ride heights, this weekend. Hope you guys can help out.
When I bought my Mk7 Sport, it was fitted with heavy duty rear springs, as it was used for towing.
The clearance in the arches was huge, and looked terrible.
I have now fitted lowered springs from MRS, but now I think it’s just TOO low.
Question is: can you buy spacers to go between the spring and axle, to raise it slightly (about 35 mm)??
I thought about using Escort/Capri aluminium lowering blocks. The springs sit below the axle on the cars, so the blocks drop the ride height. On the van, it’s the opposite.
Would this work, as the set up is basically the same??
OR
As I said above, can you buy proper parts to do this??
THANKS FOR READING
stucos71
Re: Raising MK7 Rear Suspension
Postby Airthies » Mon Apr 15, 2019 12:53 am
I've never found any, I made my own to give me more ride hight/sill clearance but there for a fully loaded t350ImageImage
Sent from my anu5 using crapatalk
Back now, well for a bit anyway.....
2008 350LWB 115PS ex fitters van + other things....
V86+patch
V86.04
X-Prog
C81
Airthies
Postby stucos71 » Mon Apr 15, 2019 1:49 am
Thanks.
I was thinking about fabricating something along those lines, if nothing was available.
I only need 30/35mm, so shouldn’t be too hard.
As long as it has the nipple and the hole, it won’t go anywhere once clamped in place.
stucos71
Postby Jim Archer » Mon Apr 15, 2019 7:46 am
If leaf springs, it's better to use longer rear link arms, puts a lot less strain on the springs.
Jim
Mk7 140 Jumbo - Vantunered.
Jim Archer
Postby stucos71 » Mon Apr 15, 2019 11:41 am
Jim Archer wrote:If leaf springs, it's better to use longer rear link arms, puts a lot less strain on the springs.
Jim
That’s me Jim.
Where would I get them from?? Is it a Ford part??
stucos71
Postby dumper » Mon Apr 15, 2019 5:28 pm
You could always remove a leaf come the heavy duty springs and refit them or put a leaf from the heavy duty springs into the lowered springs
Postby Airthies » Mon Apr 15, 2019 11:59 pm
Jim
That’s me Jim.
There's a guy on FB pages making them.
Pete Busby not sure if he's on here? But don't think so
V86+patch
V86.04
X-Prog
C81
Airthies
Postby stucos71 » Tue Apr 16, 2019 12:54 am
dumper wrote:You could always remove a leaf come the heavy duty springs and refit them or put a leaf from the heavy duty springs into the lowered springs
No guarantee what height I’ll end up with, doing it that way.
If I know I need 30/35mm, then a spacer of that size should give me exactly what I need.
That’s my thinking anyway.
stucos71
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
