I've posted about this issue before but am at the end of my tether at this point - a quick rundown of the issue and whats been done.
MK7 2.4 RWD, idles quite roughly and after a 20 min drive won't start straight back up.
With regards to error codes I have these in IDS:
Fault is currently present
P251A
Fault previously detected, not currently present
B109F
U0100
U0155
U0140
P0200
P068A
No valid status available
U0073
In September I had the timing chain replaced/fixed, as it had been done poorly before, I also replaced the EGR and inlet manifold (garage reckoned it was cracked). I did a PCM update with IDS 115.01 the other day and lastly had 2 injectors replaced back in April.
Have tried an injector test with IDS but am not certain what I'm looking for - the results are here - https://photos.app.goo.gl/ZAMBbXUYTzcagArp6
My plan is to start with replacing the PRV and family -https://www.ebay.co.uk/itm/FORD-TRANSIT ... 2759508246 - and then to move onto replacing/refurbishing injectors.
Any advice is more than welcome!
