1robbie wrote:...which everyone says is a direct swap . It's not at all a direct swap...
1robbie wrote:There is also nowhere to attach the seat belt fixing point on the passenger side galaxy seat...
andz327 wrote:Are the rails above or below the swivel plate??
ANDZ
Cider Andy wrote:1robbie wrote:...which everyone says is a direct swap . It's not at all a direct swap...
I never did in a previous question you posed about this.
Sorry guess I should have said nearly all .1robbie wrote:There is also nowhere to attach the seat belt fixing point on the passenger side galaxy seat...
All the front passenger Galaxy seats I've seen come with it already bolted to the seat, much like the Transit driver's seat.
andz327 wrote:Where does it bolt on the drivers seat.... Its just too easy to message for help , use your brain fella get the auld grey matter working instead of blaming others about your seat not fitting, as for the seat runner significance.....really....if they're above the plate then who cares where the transit runners bolt on as it'll be the plate and not the runners thats getting bolted to the box, if its under the plate then can you not just drill new holes, if runners are to short then by a couple of bits of flat bar iron, bolt them across the base then drill holes for your runners to bolt on jobs done, bolt seatbelt to the nearside rear bolt hole on seat base
ANDZ
1robbie wrote:Your very high strung are you not ?
Take a chill pill , relax and you will feel much better .
Altransit wrote:1robbie wrote:Your very high strung are you not ?
I can't quite believe that you're being rude to the guy who's trying to help you
Oh well, good luck
Jay2018 wrote:Altransit wrote:1robbie wrote:Your very high strung are you not ?
Oh well, good luck
Don't, I've fk with 500 dudes baw bags, lol I'm tired man
andz327 wrote:Thats the thanks you get for trying to help...... Nice
Now that i see he's tired cause he's been fkn with 500 dudes baw bags i can see he'd have trouble with a seat conversion
ANDZ
Altransit wrote:andz327 wrote:Thats the thanks you get for trying to help...... Nice
ANDZ
That was Jay that said that, and I have no idea what he was on about
ned wrote:glad I'm not the only one who didn't understand what Jay's on about, no more drugs for Jay
