Hiya guys, my power windows on the drivers side won't operate either window but the passenger side works fine, I checked the wiring between the drivers door and found one broken wire but that was my mirror indicator sorted now I took the drivers double switch out sprayed WD40 in both connectors but that was wishful thinking! So I tested the bigger block and there's power going to the switch BUT its clicking as if it has a connection but nothing so any help would be appreciated. Im hoping its just needing a new double switch.
Thanks in advance.
Rab
