Van struggles to start when warm
Postby jacky » Sat Jan 15, 2022 2:27 pm
My van starts no problem first thing in the morning but, say I go in for diesel then It struggles to start. The starter just cuts out then I try again. It starts on the 4th or 5th attempt. Seems to happen after the engine has heated up.
All the servicing is upto date including the fuel filter which was recently changed.
Any ideas?
jacky
Re: Van struggles to start when warm
Postby knobby1 » Sat Jan 15, 2022 9:42 pm
Possibly a tired starter, it may be full of clutch/DMF crud...often a good disassemble and clean out helps...or just replace it.
Postby jacky » Sat Jan 15, 2022 11:01 pm
Thanks for reply. So the van just wouldnt start in Asda's carpark tonight so I called out the AA. The guy got me home and said its the Head Temperature Coolant Sensor that needs replacing.
Searching on here theres a post that states the fuel pump needs to be removed to get access to change it.
Vans a 2010 2.2
jacky
Postby knobby1 » Sun Jan 16, 2022 10:01 am
jacky wrote:Thanks for reply. So the van just wouldnt start in Asda's carpark tonight so I called out the AA. The guy got me home and said its the Head Temperature Coolant Sensor that needs replacing.
Vans a 2010 2.2
You never said it was indicating overheating..??
Postby jacky » Mon Jan 17, 2022 10:34 pm
LOL Its not over heating. AA guy said the faulty sensor stops the van from starting. I know nowt about how these things work.
jacky
Postby knobby1 » Tue Jan 18, 2022 3:48 am
jacky wrote:
Really..?? Didn't know that. I know if the Cyl head temp sensor is faulty and causes the gauge to read high it will cause issues.
So does your cyl head temp read properly/correctly..??
Postby jacky » Fri Jan 21, 2022 12:31 am
Hi, yep no indication of any overheating. Im pretty sure he said something about the faulty sensor is sending a message to the computer and the van thinks its too warm so stops it starting ?? I honestly dont know how he came to this conclusion as he never run any diagnostics (No engine light on either). Vans going in next week to see what the issue is
jacky
Postby knobby1 » Fri Jan 21, 2022 10:30 am
jacky wrote:Hi, yep no indication of any overheating. Im pretty sure he said something about the faulty sensor is sending a message to the computer and the van thinks its too warm so stops it starting ?? I honestly dont know how he came to this conclusion as he never run any diagnostics (No engine light on either). Vans going in next week to see what the issue is
If the CHT sensor is faulty they should give an indication on the temp gauge. Get yourself Forscan and a modified ELM-327 and find out yourself. Forscan will do live data and give you all the info.
Postby Altransit » Sat Jan 22, 2022 2:11 pm
I would have thought that if a sensor thought the van was overheating, it would flash up a warning and then cut out, not randomly not re-start :?
Sounds more like a faulty crank or cam sensor to me :idea:
Postby knobby1 » Sat Jan 22, 2022 9:01 pm
Altransit wrote:I would have thought that if a sensor thought the van was overheating, it would flash up a warning and then cut out, not randomly not re-start :?
Agree....possibly a duff crank sensor with DMF crud all over it.
Postby andz327 » Sat Jan 22, 2022 9:21 pm
Is it turning over ok just not starting or just clicking ???????
Sent from my SM-G975F using Tapatalk
andz327
Postby jacky » Mon Jan 24, 2022 1:13 am
Hi, yes I also thought it would throw up an engine management light but it hasnt. When I turn the key in the morning it starts no problem (Cold engine). If I turned the engine off and try and re start thats when it wont. :D
When i try and start it the starter motor just cuts out after turning a good few times. Am i right in saying they are made to do that?.
It usually starts after the 3rd or 4th attempt.
Ive ordered Forscan . Thanks for that
jacky
Postby knobby1 » Mon Jan 24, 2022 6:24 am
jacky wrote:Hi, yes I also thought it would throw up an engine management light but it hasnt. When I turn the key in the morning it starts no problem (Cold engine). If I turned the engine off and try and re start thats when it wont. :D
Often poorly starters will play up when hot and come good when cold.
Postby jacky » Wed Feb 09, 2022 11:36 pm
SORTED
The fault was a faulty ignition switch.
cheers guys
jacky
