Transit mk7 won`t start
Postby phil.c » Tue Aug 02, 2022 7:04 pm
Hi guys, Transit MK7 2.2 2011 slowly died on way home tonight. Did notice a slightly different noise when I accelerated on motorway and as I slowed to come off had loss of power. Chugged along for a couple of hundred meters until I stopped at island then it stalled and wouldn`t start. Does splutter a little on ignition but no joy.
Any advice appreciated.
Phil
phil.c
Re: Transit mk7 won`t start
Postby knobby1 » Tue Aug 02, 2022 8:20 pm
phil.c wrote:Hi guys, Transit MK7 2.2 2011 slowly died on way home tonight. Did notice a slightly different noise when I accelerated on motorway and as I slowed to come off had loss of power. Chugged along for a couple of hundred meters until I stopped at island then it stalled and wouldn`t start. Does splutter a little on ignition but no joy.
Any advice appreciated.Phil
Euro-4 or Euro-5.??...2011 was the changeover year..
Have you had the codes read..??
Postby phil.c » Tue Aug 02, 2022 8:38 pm
Euro4, not had chance to get codes read yet
phil.c
Postby phil.c » Wed Aug 03, 2022 6:55 pm
Had codes read and not a lot to report. said it was having electrical issue possibly alternator but i`m not having any trouble with charging. looks like its not getting derv
out of the filter?
phil.c
Postby knobby1 » Wed Aug 03, 2022 8:31 pm
phil.c wrote:Had codes read and not a lot to report. said it was having electrical issue possibly alternator but i`m not having any trouble with charging. looks like its not getting derv
out of the filter?
If you remove the fuel filter, is it empty or 1/2 empty..??
I wonder if the fuel pick-up in the tank is not well..?? Blocked fuel filler cap breather maybe..??
Postby phil.c » Fri Aug 05, 2022 10:24 am
Removed filter and its full. Might have been wrong about fuel supply. Frustrating!
phil.c
Postby phil.c » Mon Aug 08, 2022 1:02 pm
If ignition is on should pump be sucking diesel from the filter?
phil.c
Postby knobby1 » Mon Aug 08, 2022 8:48 pm
phil.c wrote:If ignition is on should pump be sucking diesel from the filter?
No, the fuel pump is mechanically driven by the inlet camshaft on the FWD Euro-4 engine....so engine needs to be running for the pump to do anything.
