Broomlagoon wrote:Thanks mate , been looking how to flush it I seen here you can use dishwasher tablets too but not sure how to actually go about it … been hunting online no luck
Broomlagoon wrote:Thank you , I mean how does one go about going that ? Drain radiator and full reservoir with soapy water then repeat half a dozen times ? Then flush with clean water
Can you leave a hosepipe running in reservoir
But I suppose hot water with detergent will also work much better in the first few flushes
Do i do this with oil cooler taken off and obviously before fitting new one
Thanks for the help
ned wrote:I didn’t have to flush mine as it had split externally dumping oil all over the bottom of the van but I’ve heard dishwasher detergent works well.
Broomlagoon wrote:Brilliant I reckon I’m ready to rock and roll when the part arrives
Thank you Ned and knobby1 for all your help
Users browsing this forum: wardus212
