Fuel line bleeding help
Postby wombal » Mon Nov 07, 2022 11:15 am
Hi can anyone explain how to bleed fuel lines on a 2007 fwd transit please I changed fuel filter without thinking put it on empty ffs started till it used up fuel already in lines then stopped it was then I realised my error ffs
carpe diem !
wombal
Re: Fuel line bleeding help
Postby knobby1 » Mon Nov 07, 2022 8:05 pm
wombal wrote:Hi can anyone explain how to bleed fuel lines on a 2007 fwd transit please I changed fuel filter without thinking put it on empty ffs started till it used up fuel already in lines then stopped it was then I realised my error ffs
Just pull the filter off, fill it to the brim with fresh derv and refit, Mk7's are self bleeding, it will crank a while whilst the air is bled through the pump bypass but will eventually fire. As you've found, diesels don't much like air in the fuel system.
Postby wombal » Wed Nov 16, 2022 2:45 pm
Thanks yes it worked
carpe diem !
wombal
