Front brake discs
Front brake discs
Postby spainish steve » Wed Jan 25, 2023 10:35 pm
2008 mk7 transit what sort of a job to replace front brake discs cheers
spainish steve
Re: Front brake discs
Postby andz327 » Thu Jan 26, 2023 2:08 am
Easy with the right tools .... bastardo with wrong tools
Sent from my SM-G975F using Tapatalk
andz327
Postby ned » Fri Jan 27, 2023 9:31 am
Aye fairly easy you’ll need a T45 or T50 long torx bit (can’t remember exactly which one) to remove the 5 x bearing bolts, a 13mm I think it is to loosen the 5 x disc bolts, a bit 36mm I think socket to remove the hub nut which has a torque rating of fooking tight, then you’ll need to extract the hub/bearing assembly from the knuckle that’s the hardest part, easiest way is to bolt 3 long bolts into the hub where the torx came out then bolt the wheel back on, as the wheel hits the bolt head it’ll draw the bearing out of the knuckle, once it’s off it’s just a case of pull the disc off and stick the new one on then bung it all back together.
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby KevofCov » Mon Feb 06, 2023 10:48 pm
KevofCov
