DG-Unit wrote:Okay. The DTCs are in:
B1209 Instrument cluster switch bank 2 circuit failure
B1205 instrument cluster switch bank 1 circuit failure
Poorly earths somewhere maybe..??
Frag wrote:I know you may want to fix your cluster issues,and confirm it’s not flattening the batteries….
But other than if it’s flattening the batteries,cluster has no effect on starting and vehicle should start and run even without it plugged in (same for mk7)
ned wrote:Abs fault could be a duff censor or and knackered abs ring thing, I had a bent one inside one rear drum brake, nothing some pliers didn’t sort out
DG-Unit wrote:ned wrote:Abs fault could be a duff censor or and knackered abs ring thing, I had a bent one inside one rear drum brake, nothing some pliers didn’t sort out
Good shout. I forgot about the rear sensors! Do you think a fluid flush would make any difference as well?
ned wrote:DG-Unit wrote:ned wrote:Abs fault could be a duff censor or and knackered abs ring thing, I had a bent one inside one rear drum brake, nothing some pliers didn’t sort out
Not on an abs fault, it’ll either be an broken wire, knackered sensor head or abs ring, have you done any work on the brakes?
