mk7 axle
mk7 axle
Postby jasonblacktransit » Sat Feb 18, 2023 1:40 pm
has anyone on here done mk7 axle onto mk6. i need help from someone who has made it work..
jasonblacktransit
Re: mk7 axle
Postby knobby1 » Sat Feb 18, 2023 9:28 pm
jasonblacktransit wrote:has anyone on here done mk7 axle onto mk6. i need help from someone who has made it work..
Many have done it....brake flex lines, ABS reluctor rings, (if fitted) and hand brake cables are the main differences. Some have a different prop shaft coupling and spring mounts too.
Re: mk7 axle
Postby jasonblacktransit » Sun Feb 19, 2023 9:27 am
yeah i have done all of that. still no brakes so im going to change master cylinder and servo to a mk8 . this is 28mm and the mk6 is only 25mm so hopefully should move more fluid
jasonblacktransit
Re: mk7 axle
Postby jasonblacktransit » Sun Feb 19, 2023 6:21 pm
IS ANYONE OUT THERE THAT HAS DONE THIS............ PLEASE SOMEONE ANSWER......ITS NOT A STRAIGHT SWAP... AND THE USUAL COMMENT OF LOADS HAVE DONE IT REALLY IS GETTING ME DOWN. THERE WILL BE A CHEAP FIRE DAMAGED MK6 ON HERE FOR SALE VERY SOON.
jasonblacktransit
