Panels
Panels
Postby loot » Sun Jan 14, 2024 10:36 pm
How come they're grossly over priced :shock:
Plastic wheel arch liner 100 quid minimum.
Front wheel inner arch repair panel 75 quid. Etc
07 350 170ps
Ids map here
loot
Re: Panels
Postby Airthies » Mon Jan 15, 2024 1:35 am
Covid and brexit you choose.
Sent using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: Panels
Postby andz327 » Tue Jan 16, 2024 3:14 am
Airthies wrote:Covid and brexit you choose.
And noo the Houthies
andz327
Re: Panels
Postby gotgcoalman » Thu Jan 18, 2024 5:22 pm
It's the exchange rate of Welsh turnips is not very good at the moment
Have they dropped off?
Too bloody quiet :shock:
gotgcoalman
Re: Panels
Postby loot » Fri Jan 19, 2024 6:46 pm
I refuse to pay the tax man's extortion. I'll make my own panels damn it or get cheap ones :P
07 350 170ps
Ids map here
loot
Re: Panels
Postby gotgcoalman » Fri Jan 19, 2024 8:24 pm
A couple of washing machines and a selection of hammers
gotgcoalman
Re: Panels
Postby knobby1 » Fri Jan 19, 2024 9:13 pm
gotgcoalman wrote:A couple of washing machines and a selection of hammers
Many washing machines are made of plastic these days....won't rust though..??
Re: Panels
Postby gotgcoalman » Fri Jan 19, 2024 9:34 pm
If that's the case a blow torch will be needed to shape them.
It'll be like carbon fibre only slightly crap.
gotgcoalman
Re: Panels
Postby sherwoodcycles » Thu Jan 25, 2024 11:40 pm
I repaired a broken washing machine drum bearing years ago. Felt really proud. Big plastic drum. The drum had dropped and was rubbing on the outer drum because of the failed bearing.
I cleared all the plastic shreds from the pump and tried not to scoff with pride as the machine performed a other wash. My housemates at the time were literally clapping. I was so so chuffed and smug.
'Honestly guys it's nothing' I said - secretly clapping to myself.
That's when the water and foam started to pour out as the outer drum split with the vibrations (it had of course been heavily scored by the inner drum after the bearing had collapsed) .
It was very embarrassing but the floor was clean.
We bought another washing machine.
Buy some secondhand liners. I've got one, just need to try to install it.
Greeny
sherwoodcycles
