Transit 2000-2006, 2.4L Duratorq (85kW/115PS), Diamond White 73
VIN Number: WF0LXXTTFL5B03245
Registration Number: DS05FWO
First Registration Date: 08.07.2005
Registration Country: GB
Primary Features
Build Date: 02.05.2005
Vehicle Line: Transit 2000-2006
Cab Style: Regular Cargo Van
Series: 1.7-350L Series
Engine: 2.4L Duratorq (85kW/115PS)
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.13
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
A Good day to all,
I will try and keep this short.
I have had small end bearing damage in one conrod and I have noticed prior to this ring wear on stripping engine down, so I am changing all the rings and bearings whilst the engines dismantled. It's the first time I have done this work.
The main issue I need help/info with is:- ''I have a problem with sourcing rings. I checked on various sales catalogues and basically for what i believed was my vehicle I.D over the years was as above and an FXFA code on vin searches too and other parts ordered.
All or most searches come back as ring size Ring 1, 2.50 mm Ring 2, 2.00 and ring 3 and 3.00mm. Like an idiot but due to everything else going on I spent some time and ordered a set of rings at those specs, yet took it as fact.
When they arrived I started to clean pistons and remove old rings and noticed they were all 2.00mm.
If I try and find 2.00mm rings the closest I get is for a JFXA code and others, but all are in a very different engine group from the F4FA 75ps, D2FA,D2FB,HEFA 90ps, ''FXFA 115ps'', D4FA, DFFA 120ps, DOFA 125ps and the H9FA 135ps group.
Mine has always come up as TDE too and mainly MK6 TDE but sometimes MK5 TDE with years from 200 t0 2006 but often 2004-2006.
I can find many for the 2mm for the bore size of 89.9 and would be happy fitting these if bores just need a hone after taking checking ring end gaps in situ, which I hope will be fine as there is still much crosshatching inside the bores. Currently at 165,000 miles.
I would appreciate anyone's experience and or knowledge on this. I will check regularly to respond to replies.
There's questions I need to ask, but I will save them for the none technical area's of the forum.
I hope I have the correct section.
Thank you.
