Simontfs wrote:I have a large air bubble in the fuel line just before it goes to the engine (pump?) how do I get rid of this air bubble. I changed the filter last week and didn't notice it. The van Starts after a couple of tries, and runs ok, but its obviously not supposed to have an air bubble, I'm guessing this would cause a low pressure into the engine not giving me all the power compared to if there was no air bubble in the line. Can I take the black plug off the side of the engine raise it up so the bubble comes to the top, turn the key to take up gap from the air in the pipe and reconnect the plug in the side of the engine. Can Anyone help? The Yellow Highlight is where the bubble is in the line that runs behind the air intake tube, and the red circle is the black plug id like to remove to try to get rid of the air bubble. Please help, as this is causing starting problems.https://drive.google.com/file/d/1YTcW0Sj0BnFGjIaW-FpRMNBhkAg3bvIJ/view?usp=sharing
Simontfs wrote:Good evening Lord Knobrot,
Thank you so much for your reply![]()
So to confirm, its a Euro4 2.2 Tdci FWD. I should have mentioned that I Had replaced the Diesel Filter. I bought one filter, that didn't fit properly, so Then I had to order another one, and now it fits good. The air got into the system During the messing around with the diesel filters. I can confirm that it hasn't gotten worse or better, but that the damned bubble is still there.
Not sure but Could this cause a slightly erratic idle, and a slight loss of torque/power?
The ambient temperature has risen slightly and the van starts almost every time fist time, sometimes second times, but I believe that is a glow plug issue that I will use Forscan for in the near future. Possibly tomorrow. and I'm sure ill need help deciphering these codes; but that's another issue.
I changed the oil two days ago, and made the most of the situation and removed the aircover, here's the link, where the air bubble is visible.
https://photos.app.goo.gl/VHkyAw8oXR34ssrH9
I hope that you can guide me step by step to get rid of this damn bubble. Thank you so much for you help.
PS you will notice other issues in this video...AKA the injector seals etc, but that's gonna be in another post, as I have a bunch of questions about that.
