I recently purchased a ELM 327 500K obd2 diagnostic thingy and i must say i am impressed with its abilities, for only £17 it comes with a cd to install forscan on your laptop and usb cable, just plug it in and away you go, anyway i had this plugged into my 2011 2.4 jumbo to help diagnose the temp gauge not working, i was thinking the fault was with the new cht sensor i had fitted but thanks to my new gadget i can see that the sensor is working as is the dashboard gauge. I had the engine sat idling for about a hour and no movement on the gauge but forscan was telling me the temp was in the high 40s i took it for a run and it went up to 56 degrees then cooled back down to mid 40s again, it was a cold day, the thing is the gauge starts at 60 degrees so my engine is not getting warm enough to make the needle move, i removed the thermostat a few weeks back as it was not working so i just left it out then the head was sent for skimming with the cht sensor still in place after which the temp gauge stopped moving
i thought it was the sensor so i changed it for a new one, no change, i would like to ask the panel would removing the thermostat cause this what looks like a cool running engine and also would this cool state cause any issues such as over fueling, i will be fitting a new thermostat this weekend to see what effect it has
