Oil pump tightening torque
Postby Gordonwimsey » Fri Aug 09, 2024 11:20 am
Hi. I have a 2012 2.2 with a CYCA engine.
I have searched relentlessly for the tightening torque for the banjo bolt on the oil pump return pipe. If anyone could help me with this, it would be dandy.
Gordonwimsey
Re: Oil pump tightening torque
Postby metalworker0 » Fri Aug 09, 2024 3:42 pm
This is an online page from the workshop manual-
Note; workshop manual not often accessible or searchable..just searchable via google image search --- sometimes--- they let you see selected pages, hoping you'll buy
anyhow the torques are here ,..hopefully
think it may be instruction number 15
note carefully the other instructions about measuring
have a look yourself ..after setting cookie preferences
https://workshop-manuals.com/ford/trans ... ly/engine/
Postby Gordonwimsey » Sat Aug 10, 2024 2:07 pm
Hi Mark.
Thanks for your reply. Have checked detail but only shows the four bolts for the actual pump and pick up pipe itself, but not the banjo bolt on the return pipe on the right on my image. As this is a hollow bolt i didn't want to shear it. I may have to add a little loctite to the thread and torque to 6nm.
Regards. Bill
Gordonwimsey
Postby metalworker0 » Sat Aug 10, 2024 3:30 pm
Here: land rover defender manual . same engine. you may find the detail in that. .
looks a lot better than the ford one ..no stupid blue diagrams ..more detail
but no quick index
so once down loaded and opened up, search within by typing "oil pump" etc
how to get it ...don't view online ..download the entire pdf - over 1200 pages
note: tick box next to file named "workshop manual" ...look at the top and press down load
2007 on
https://onedrive.live.com/?authkey=%21A ... 9C85C7C171
for you 2012 on
if someone can store these manuals online ..just in case they disappear ..then do it edit the pdf so it's just the engine bit.
Postby MinorMatt » Mon Aug 12, 2024 2:02 pm
metalworker0 wrote:Here: land rover defender manual . same engine. you may find the detail in that. .
but no quick index
2007 on
for you 2012 on
The full links haven't been posted....
