Mk7 from 2013 Over revving then loud rattle and now wont sta
Postby garden guru » Thu Aug 22, 2024 9:54 am
Hi
My 2013 2.2 mk7 has developed an issue of over revving and it goes well high to around 6000rpm and then puts van in limp mode.yesterday even worse it did this then after a restart (breakdown told me i was safe to drive). I got a really high rev and could hear like a loud ticking noise. it then became like a loud rattle noise from what seemed passenger side of engine. it stopped and my dad towed me home. it wont start now just getting a click on ignition. We tried a jump pack but nothing. I have put a spanner on the fan pulley and it turns and I can hear/feel compression. Could it be a blown turbo (only replaced it 3 months ago? Any ideas where to start? thanks
garden guru
Re: Mk7 from 2013 Over revving then loud rattle and now wont
Postby knobby1 » Thu Aug 22, 2024 9:53 pm
garden guru wrote:Hi
Not possible for it to rev to 6000rpm...they have a hard rpm limiter @ 4500rpm...unless you've had a "diesel runaway", then the rpm limiter will not work. At 6000rpm there would probably be conrods hanging out the side of the engine block. Is it blowing a lot of white/blue smoke..??
Postby Jezclayton » Fri Aug 23, 2024 4:35 pm
I had a "diesel runaway" on my 07 Mk7 and the problem you describe made me think of this straight away. As LK said, revs were way over the 4500 rpm mark and the only way I could stop the engine was by stalling it from stationary in 5th gear. There was more smoke than I have ever seen come out of a van. No conrods hanging out of the side of the block, but upon inspection a hole was visible in the top of piston no1, no doubt caused by a faulty injector. According to the mechanic I sold the van to, surprisingly the engine suffered no damage other than the piston, though I assume he also sorted the injectors. See the following link for more info on "diesel runaway":-
https://www.team-bhp.com/forum/technical-stuff/204960-diesel-engine-runaway-what-how-stop.html
By memory, piston 1 is on the passenger side and I seem to recall there was a recall in relation to injector issues on this side though this was surely sorted by 2013? If you had no smoke when the engine was over revving it is unlikely to be a holed piston. A compression check would confirm this. The loud ticking developing into a loud rattle is of concern, but better than a loud knocking. If you had no smoke, first thing I would do is remove the starter motor (also on passenger side) and check for visible damage to the gearing (broken teeth etc.). If OK, install new starter motor and check if the engine turns over smoothly. You never know, it may even start. If the engine does start and the noise has gone away maybe the cause was the faulty alternator. If the noise is still there, another possible cause for the rattling you describe is failure of the dual mass flywheel (if fitted). How would this cause over revving, my guess would be damage to the crankshaft position sensor.
I should finish by saying I know nothing :roll:
Current - Custom 300 L2H1 DCIV Limited 2.0 EU6.2 170ps Auto 09/22
Previous - Custom 290 L1H1 DCIV Limited 2.0 EU6 170ps 09/17 (Sold)
Previous - MK7 SWB 140 T280S Limited 2.2 FWD. 03/12 (Stolen)
Previous - MK7 MWB 130 T300 GLX 2.2 FWD. 04/07 (Sold)
Jezclayton
GLX Posse
Postby knobby1 » Thu Aug 29, 2024 7:17 am
Jezclayton wrote:By memory, piston 1 is on the passenger side and I seem to recall there was a recall in relation to injector issues on this side though this was surely sorted by 2013? If you had no smoke when the engine was over revving it is unlikely to be a holed piston. A compression check would confirm this. The loud ticking developing into a loud rattle is of concern, but better than a loud knocking. If you had no smoke, first thing I would do is remove the starter motor (also on passenger side) and check for visible damage to the gearing (broken teeth etc.). If OK, install new starter motor and check if the engine turns over smoothly. You never know, it may even start. If the engine does start and the noise has gone away maybe the cause was the faulty alternator. If the noise is still there, another possible cause for the rattling you describe is failure of the dual mass flywheel (if fitted). How would this cause over revving, my guess would be damage to the crankshaft position sensor.
#1 cylinder on the FWD's is on the driver's (right) side. He has a RWD so #1 cyl is at the front.
He hasn't been back since the 22nd so we may never know.
