First post here and have searched but not found an answer to what I’m looking for.
Have both aux and starter batteries out of a 63 plate transit. It had a Merlin battery protection system installed by uk power. We have removed it.
Do we need to reinstall a relay or split charge relay between the six and starter? As in, will it have been relocated to the Merlin system or will it still be in situ? Daughter is saying a split charge relay is needed. . I think there will be a relay already between the two batteries and we will only need a split charge relay when we install the leisure battery.
Thanks in advance!
