Both head lamps stopped working
Postby Drew10 » Sun Dec 29, 2024 1:51 pm
Both of my head lights have stopped working at the same time. The rear lights, full beams, fog lights and driving lights are working fine. I’ve checked the fuses and lamps but can’t seem to find the issue.
Drew10
Re: Both head lamps stopped working
Postby knobby1 » Mon Dec 30, 2024 9:20 pm
Drew10 wrote:Both of my head lights have stopped working at the same time. The rear lights, full beams, fog lights and driving lights are working fine. I’ve checked the fuses and lamps but can’t seem to find the issue.
Mk6 or Mk7..?? You don't say which you have...they are quite different.
If Mk7...they run separate fuses for each side.....My guess is your headlamp switch may have failed.
Still worth re-checking fuses 51, 52, 53 & 54 on the BCM behind the glove box...(If it's a Mk7).
