Limited Slip Diff
Limited Slip Diff
Postby rallyevo3 » Sun Dec 11, 2005 8:29 pm
Can you get an LSD for a 98 smiley face (MK5)?
How common are they?
What the chances of finding one in a scrapper?
Will one fit from anything else? capri atlas axle for example..
Ian
rallyevo3
Postby Nighthawk » Sun Dec 11, 2005 11:04 pm
IIRC there was no option to have a limited slip differential on the 95 series.
On the 98 model, you could specify BTCS which was a brake traction control system.
This gave the same effect as the limited slip, upto 25mph the speed signals for the ABS were monitored and if the slip was greater that a predetermined level on 1 wheel, the ABS applied the brake to that wheel. This has the effect of sending the drive to the other wheel.
The timkin axle on transit MIGHT be able to take the diff unit if it's the right size to bolt the crown wheel.
If you have the bigger salsbury type axle (15" wheels) you'll have to look for an SVO equipped Transit rear axle, there weren't that many of them tbh.
Nighthawk
Postby rallyevo3 » Sun Dec 11, 2005 11:09 pm
No ABS and 15" wheels therefore salisbury axle :(
what's SVO?
Looking like a non-starter for this mod :cry:
rallyevo3
Postby stevew » Sun Dec 11, 2005 11:35 pm
Special Vehicle Options?
Why do you want one? Are you having grip problems?
Steve
stevew
SVO
Postby Terry » Sun Dec 11, 2005 11:36 pm
SVO is/was Special Vehiocle Operations, a department within FMC.
that did what it says on the tin !
Pallet Puller
Terry
Postby rallyevo3 » Mon Dec 12, 2005 9:46 am
I park in a Paddock and it's slightly uphill to the gate.... with an unladen Tranny having as much grip as a tomato on ice an LSD would be a major improvement
rallyevo3
Postby Nighthawk » Mon Dec 12, 2005 10:39 am
It won't give that much more grip to be honest in those conditions, instead of spinning one wheel, youll spin them both as you try to pull away :cry:
Tyres with a more open tread pattern are the way to go, although road noise will increase.
If your parking up on slippy grass a lot, why not consider parking the back wheels on boards?
You know, like they do with the off roaders, the boards are connected to the vehicle by a cord...maybe 10ft long so as soon as you gain traction you pull the boards behind you untill your on the harder ground.
Might be a bit too hardcore though :lol:
Or try not parking head onto the incline, try it at a 45 degree angle so the weight is transfered more to one wheel.
Nighthawk
Postby MrMPuk » Mon Dec 12, 2005 1:09 pm
I would say try putting some weight in the back!
Postby bazw » Mon Dec 12, 2005 4:51 pm
if you want to price 1 try
http://www.quaife.co.uk/
they do lsd's but they are an arm and a leg
a manta one is £550 + the vodka and tonic
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby rallyevo3 » Mon Dec 12, 2005 5:01 pm
Just a thought.... do ambulances have them?
rallyevo3
Postby Nighthawk » Mon Dec 12, 2005 5:09 pm
Some of the twin wheel ambulances did have the option, but not all of the fleets took the option.
If you find a vehicle, jack one rear wheel up, try and spin it by hand...if you can spin it, it's a normal diff.
I've never checked if the same components are fitted between the type 51 and the 51a axles.
Nighthawk
Postby rallyevo3 » Mon Dec 12, 2005 8:09 pm
51 & 51a?
rallyevo3
