Puff of smoke
Puff of smoke
Postby ColinJack » Sat Mar 29, 2025 6:36 pm
I have just had the turbo rebuilt on my 2.5 TDi and fitted new injectors.
Runs nicely, slight smoke haze on acceleration, but getting a puff of white smoke when I lift off.
Is this normal?
Had to replace injectors because lost a tip ... so may be just residual excess diesel in the exhaust system?
1989 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Re: Puff of smoke
Postby metalworker0 » Sat Mar 29, 2025 7:17 pm
when the turbo failed it may have put a lot of oil into the exhaust and intercooler.
This will have to be burnt off .
It may right itself - after a long run..if it does not
Then come back here.
Re: Puff of smoke
Postby ColinJack » Sat Mar 29, 2025 7:20 pm
metalworker0 wrote:when the turbo failed it may have put a lot of oil into the exhaust and intercooler.
Cheers Mark. That is what I suspected.
Cleaned out the intercooler and pipework but not the exhaust so will see how it goes with a run.
Its white smoke so will be fuel.
ColinJack
