Found a bolt
Found a bolt
Postby FDN850HU » Sun Jun 22, 2025 6:32 pm
Hi members, while cleaning the front crossmember, i came across this bolt. Pretty distorted, worn etc, could anyone recognise this thing, is it genuine Ford or something else? My 96 2.5di bus is just after a new clutch, rear main oil seal and other surgeries, i hope it does not belong to any of these parts (its m6 threading). Tia
FDN850HU
Re: Found a bolt
Postby knobby1 » Sun Jun 22, 2025 8:28 pm
Clutch pressure plate bolt maybe..?? Rear main seal retainer plate bolt..??
Re: Found a bolt
Postby MinorMatt » Mon Jun 23, 2025 9:03 am
The only M6 bolts I can think of in that area are the 2 that hold the sandwich plate at the bottom of the bellhousing - with are a PITA and most people leave out anyway.
The bolts that hold the oil seal housing in may also be M6 - but there are lots of them so one wouldn't be a worry to me. I think they are M8 though (and flanged).
I wouldn't get worried about it.
Re: Found a bolt
Postby andz327 » Tue Jun 24, 2025 1:43 am
In the trade that's called a comfae bit...... where the fook did that come fae
If there's no hole to be seen then Good chance that bolt been replaced cause mechanic lost it
andz327
Re: Found a bolt
Postby FDN850HU » Tue Jun 24, 2025 6:15 am
Thanks all of you. Lots of dirt came out from the crossmember, also pebbles, it might have been there for long time. I ve got a sandwich plate, what is its function? Thanks
FDN850HU
Re: Found a bolt
Postby gotgcoalman » Thu Jun 26, 2025 7:22 pm
Rocker bolts are m6 aren't they?
Gravity dictates something fumbled at the the top will end off somewhere lower down.
Vroom vroom
Too bloody quiet :shock:
gotgcoalman
Re: Found a bolt
Postby FDN850HU » Fri Jul 04, 2025 10:34 am
got all rocker cover bolts, that gasket was done too but no missing bolts there fortunately. cheers
FDN850HU
