FORScan Live Data - Multiple "Error" readings on 2014 2.2L D
Postby 89transfers » Tue Jan 06, 2026 1:09 am
I’m currently running some diagnostics on my 2014 Ford Transit (2.2L Duratorq Stage VI) using FORScan v2.3.68. While checking the dashboard, I’m seeing "error" listed for several parameters, specifically:
1.- COSF, CTSF, CFSO, CFSTH
2.- THSF
3.- %%H(THSO)
Is it normal for these PIDs to show as "error" on this engine model? The van seems to be idling fine (around 840 RPM) and cylinder balance looks healthy, but I’m wondering if these errors mean the sensors are missing, the ECU doesn’t support them, or if there's a communication issue with my OBD2 interface.
Any insight from fellow Transit owners or FORScan experts would be appreciated!
89transfers
Re: FORScan Live Data - Multiple "Error" readings on 2014 2.
Postby metalworker0 » Tue Jan 06, 2026 1:21 am
Perhaps you're adding pids that don't exist
i looked up a few of them acronyms.. they don't even show on google
unless you are in a foreign language section of forscan and they have other acronyms in English
