Torque settings for 2.0 eco blue RWD clutch
Postby Ryan9153 » Fri Feb 13, 2026 3:58 pm
Hi guys hope this helps others as it was a pain for me to find. Just done a clutch on one of my ford Transits 2019 RWD 2.0 litre eco blue.
These are the settings if you need them.
Dual mass flywheel to engine x8 T60 torx bolts, Stage 1 15NM, STAGE 2 30NM, STAGE 3 75NM, STAGE 4 another 45 degrees.
Clutch to DMF x6 bolts 2 turns at a time opposite bolts, tighten to 10NM THEN 20NM THEN 29NM.
SUBFRAME NUTS FRONT OF SUBFRAME 175NM, REAR SUBFRAME LONG M16 bolts 275NM.
PROPSHAFT TO GEARBOX x3 bolts 21mm heads through rubber damper. 175NM.
I USED ALL NEW BOLTS EXCEPT SUBFRAME BOLTS. ANY QUESTION PLEASE ASK I will try and help.
Ryan9153
