Brake pipe rusted
Brake pipe rusted
Postby matts09transit » Tue May 12, 2026 7:53 am
Hi everyone.
I have a rusted brake pipe underneath the brake fluid reservoir on the left side when looking in with the bonnet open. It's the pipe that goes round the back of the engine block which seems like a real pain to replace. Has anyone done it or done something similar? As far as I can tell me options are:
1. Replace the whole pipe with an identical part
2. Replace the whole pipe with a homemade copper pipe and flaring kit
3. Cut the rusted section and join homemade copper pipe
Any considerations I need with the fluid when doing this?
Ford Transit Duratorq Common Rail Injection 2.4L RWD 100HP 2008
Thanks,
https://postimg.cc/cvJ78Lbc
matts09transit
Re: Brake pipe rusted
Postby Sam123 » Tue May 12, 2026 10:20 am
At least with my Mk8, which is obviously newer, I don't think Ford even supply the original parts anymore. They all seem to be discontinued, and the Ford parts database seems to just provide generic pipe by the metre.
Sam123
Postby metalworker0 » Tue May 12, 2026 1:55 pm
there are genuine ford brake pipes on ebay .. £30 - £50 or round abouts
me not knowing the mk7 cant pick one out for you because some of the descriptions are vague, some ford listings with no picture .. and no info from you if left hand drive or right hand (they are different)so its a case of you know what it looks like and looking at the pictures.
here's the parts diagram page
http://www.catcar.info/ford/?lang=en&l= ... A9PTIwNjA2
may help you out a bit , as putting the part number into ebay gets you the right one
if putting a piece in .. you need to go from a good section too a good section .. no use leaving that crusty white spotted stuff in place.
if it had been a fwd .. i would have said .. support engine, undo mounts and lean engine out of the way.
its up to the guys here who know now to give you some help
Postby knobby1 » Tue May 12, 2026 7:46 pm
matts09transit wrote:Hi everyone.
Thanks,
Brake pipes etc are fitted at the factory before the engine/gearbox goes in....makes it near impossible to fit the genuine pipes without bending them all out of shape, (if you can get them)...most of us use a length of copper pipe with the correct fittings and "manipulate" it to fit as best we can.
Lord Knobrot (Smithy)
Postby dumper » Wed May 13, 2026 12:23 pm
As above make your own
Postby andz327 » Fri May 15, 2026 5:09 pm
choice #2
andz327
