central locking
central locking
Postby gemini » Wed Feb 08, 2006 3:04 am
should it work from any door or just the drivers, 95 custom swb
gemini
Postby 100ps_drw_hicube » Wed Feb 08, 2006 12:00 pm
only going by my hicube it should work from both front doors and on my van there aint even a lock barrel in the side door :shock:
100ps_drw_hicube
Transit Abuser!!
Postby Valsheda » Wed Feb 08, 2006 12:08 pm
Mine works from both front and back doors , the side door locks and unlocks as part of the central locking
Valsheda
Top Tourneo Owner
Postby gemini » Wed Feb 08, 2006 1:09 pm
same here no lock barrel on side door, key opens & locks all from drivers door, only locks passenger and back door, wont open them with or without battery connected,
so it sounds like two problems,
needs new bits inside the barrels on passenger & back so they unlock, i have a few left over from last time but probably not the right numbers,
and the central locking on the passenger door is not activating the other locks, anyone know what this will be
gemini
Postby 100ps_drw_hicube » Wed Feb 08, 2006 2:01 pm
i had this problem with the passengers door when i replaced the door ended up with a new lock/catch from fords £55 :shock: the manual one was £3 cheaper so i thought it was a good price :?
100ps_drw_hicube
Transit Abuser!!
Postby crazyscoot » Wed Feb 08, 2006 7:01 pm
My central lockings gone loopy doo!! If i set the alarm with the alarm fob some doors lock and some dont, :shock: then unlock it and the doors that wern't locked ,lock! :shock: Its drivin me mad at the moment but i'll have to put up with it untill the weekend, then have a look. :cry:
Negative reality inversion
crazyscoot
