wineing noise
wineing noise
Postby bubble » Tue Mar 28, 2006 8:38 pm
i have a 120 swb 99 tranny and it wines a bit ,when i dip the clutch it stops is this a common thing ? also my indicators fail sometime then they come on again any ideas?thanks richie
bubble
Postby FredTransit » Tue Mar 28, 2006 8:39 pm
Sounds like the clutch plate is on it's way out. I don't know if this is one of the models that have to have a flywheel change too when the clutch goes.
FredTransit
Mk2 Trannyist
Postby Luke » Tue Mar 28, 2006 8:42 pm
or release bearing? :?
Postby bubble » Tue Mar 28, 2006 8:43 pm
yeh i thought maybe that but there is plenty of clutch there.
bubble
Postby 100ps_drw_hicube » Tue Mar 28, 2006 8:45 pm
bubble wrote:yeh i thought maybe that but there is plenty of clutch there.
is it a turbo di or n/a :? as said before release bearing is the only thing i can think of :?
100ps_drw_hicube
Transit Abuser!!
Postby bubble » Tue Mar 28, 2006 8:49 pm
its just a 2.5 di 65000 miles
bubble
Postby 100ps_drw_hicube » Tue Mar 28, 2006 8:53 pm
well if it was a turbo then i would say ur induction hose had a slight leak as they do the same noise as a release bearing :x dont know of any other things it can be :?
100ps_drw_hicube
Transit Abuser!!
Postby bubble » Tue Mar 28, 2006 9:00 pm
thanks for your help i suppose it could be the gear box or diff ,like the look of your van nice.
bubble
Postby madmark » Wed Mar 29, 2006 4:42 am
it will be the clutch release bairing,has the clutch been replaced recenly????? i had this on a van a few years ago but it bedded itself in and then shut up! :?
Postby rover » Wed Mar 29, 2006 8:22 am
Does it do it when standing still? If so then I agree with everyone else, if its only when you are on the move then it will be the diff bearings.
Rover.
rover
Postby Rolo » Wed Mar 29, 2006 11:26 pm
Can the condition and adjustment of the crown and pinion also be the cause of diff whining?
1973 drw; Falcon 250 c.i.; 12v fuel pump; belt-driven water pump & fan replaced with 12v water pump & two 12" fans; T5 gearbox; Mark II front discs.
Rolo
