White smoke at start up
Postby mrmcgoo » Sun Apr 02, 2006 4:04 pm
1. I have a '92 swb 2.5 Diesel, when i start it up any time, it coughs out a large amount of white smoke. After two or three minutes then it runs normal. It is a bit noise aswell compared to other diesels, it sounds like a heavy knocking. Drives fine and cruises happily at 70 mph... Please can someone tell me how to stop it from smoking?
2. It has the bosch FIP fitted, no pre-heat, with the air filter to the side of the engine. There is are two ball joint connections that i assume should have something attached to them. One on the FIP the other on the truncking to the air filter.
mrmcgoo
Re: White smoke at start up
Postby MrMPuk » Sun Apr 02, 2006 4:18 pm
mrmcgoo wrote:2. It has the bosch FIP fitted, no pre-heat, with the air filter to the side of the engine. There is are two ball joint connections that i assume should have something attached to them. One on the FIP the other on the truncking to the air filter.
Sounds like someone has disconnected the EGR, that's nothing to worry about.
Post subject: Re: White smoke at start up
Postby mrmcgoo » Sun Apr 02, 2006 5:08 pm
cheers for that info, have you got an idea about the first concern??
mrmcgoo
Postby gemini » Sun Apr 02, 2006 5:18 pm
timing??
gemini
Postby mrmcgoo » Sun Apr 02, 2006 5:32 pm
cheers, will get a haynes manual and have a go at the timing.
mrmcgoo
Postby MrMPuk » Sun Apr 02, 2006 5:35 pm
I doubt very much it will be timing!
When you say noisey compared to other diesels are you comparing it to other Transits because they are noisey compared to most other diesel motors.
Postby rover » Sun Apr 02, 2006 5:52 pm
White smoke is most likely either water or air ingress in the fuel line/filter, if your filter has a screw cap on the bottom (it should have) just put a container under it and open the screw for a few seconds, when you remove the container you should be able to see any water that was in there.
If its air leakeage its harder to trace, but make sure all unions are tight (not too tight or the seals will split).
Rover.
rover
Postby mrmcgoo » Sun Apr 02, 2006 7:59 pm
cheers, I am going to give the van a full service as it looks like it has not been done for a few years. As i have just bought the full kit on EBay.
I will then check all the unions as well.
Many thanks.
mrmcgoo
Postby mondeoman » Tue Apr 04, 2006 7:39 pm
Hi I have got the same problem with white smoke at start up then clears after a while and it has been diagnosed as having low compression on 2 cylinders which when the engine is cold do not produce enough compresssion to ignite the diesel, as you say it runs rough until it warms up . it was mentioned that it might be because the con rods are bent which could be the knocking you are talking about.
mondeoman
Postby mrmcgoo » Tue Apr 04, 2006 9:21 pm
Gave it a full service this evening, the fuel pipes to the filter where loose. All are tigh now, started it up she smoked for a while then it faded away. I Will wait till tomorrow and see what its like early morning and after a good run.
Thanks for the advice all.
PS. does any one know of a good sray painter near Aldershot?, as she needs a good paint job, to bring her back to life.
mrmcgoo
Postby gemini » Tue Apr 04, 2006 10:41 pm
mondeoman wrote: it was mentioned that it might be because the con rods are bent which could be the knocking you are talking about.
it is unlikely that 2 conrods will be bent, 1 maybe as this is normally caused by water entering the cylinder and hydraulicing, it wouldnt cause knocking but it does make the big end shell wear unevenly
gemini
