I done a similar swap a few months ago, unfortunately the new clocks were from a Mondeo Petrol, but I went ahead anyway and even pulled a new pulse wire from Alternator.
I couldn't calibrate the rev counter correctly as it was designed for a petrol engine (Higher revs), that pissed me off as everything else worked ok.
I swapped over the internal guts from my original Fuel Gauge and when I knew I had a full tank I set the indicator hand to full.
Make sure you have the ignition on and that it is working before locking the hand in place.
I had no problems, but I changed back to old clocks as Rev Counter was useless which was the reason for changing.':cry:'
I'm still on the lookout for a Mondeo Diesel clockset with around 80k miles.
Dismantlers want too much for clocks 60 euro as they may think that we're fiddling the clocks in prep for sale, I think.
