2.5d on 3 cylinders
2.5d on 3 cylinders
Postby gazza » Wed May 25, 2005 2:50 pm
right heres another tip for you all, every now and again my 99 transit would loose power and run on 3 cylinders, it would clear after a while tho, the last time it did it was just before porlock hill in north devon, lucky it cleared before the hill :shock: , had a thorough investigation and couldnt find the usal air leaks in fittings / pipes, :? i then purchased a ford tech cd off ebay just out of intrest realy, on it i find a section on 2.5 d tranys with "intermitenet power loss and misfiring" it turns out it is to do with the leak off rail, standard they are plugged at no 1 injector and connected to the tank return at no. 4 injector, to give a reserve of fuel higher than the highest point (no.1 injector) and to stop air getting in you have to swap the plug to no. 4 injector and the return to the tank to no. 1 injector, you will need 700mm of leak off rail pipe to connect no. 1 injector to tank return, clip the new piece of pipe higher than no.1 injector and hey presto no more reduction in performance, this mod cost the grand total of £1.00 for a 1 meter length of pipe from my local motor factors and 20 mins to make a neat job of it. once you have done it take the van for a quick spank down the road then get a beer for a good job well done. if it misfired and didnt clear just crack off the union on no. 1 injector whilst the engine is running untill all the air is out and it runs sweet again
gazza
That might be the gordic knot
Postby Josef M. » Wed May 25, 2005 8:07 pm
My '99er no turbo has the back as well form the 4th injector.
Tell me, did you have a great perfomance difference between winter ( cold dry air ) and summer ( warm to hot air with often high humidity ) ?
I think i can tell the felt difference at least between 5 to 10 hp's.
Do you think that could be the leaking problem as well in addition ?
Greetings from bavaria.
Josef
Josef M.
Postby MrMPuk » Wed May 25, 2005 8:43 pm
Cold air will always give better performace as it can expand more.
High performace and large diesel engines will always cool the air first.
I know..
Postby Josef M. » Wed May 25, 2005 9:07 pm
MrMPuk wrote:Cold air will always give better performace as it can expand more.
Well Mate,
i know that behaviour but i discribe the difference like
Irschenberg ( well known german autobahn hill )
Summer max 3.gear with about 60 km/h
Winter easy 4. gear with about 85 to 90 km/h.
I think that difference is about to much to cause only from the
colder air, it must have a second reason which i'm searchin' now for
about 3 years :?
Josef
Josef M.
Postby gazza » Thu May 26, 2005 1:24 am
everything from a 50cc moped to a 2.5d van will feel better with a cool dense charge, what you are trying to avoid is a sick running motor! diesels dont take kindly to air in the high pressure lines!, have you had the same probs i encountered? my mate also has a 99 van that does the same as mine did before the mods
gazza
Postby FredTransit » Thu May 26, 2005 8:25 am
Two newbies in one post! Welcome you two, and big thanks for the info.
FredTransit
Mk2 Trannyist
Postby Josef M. » Thu May 26, 2005 7:32 pm
gazza wrote:everything from a 50cc moped to a 2.5d van will feel better with a cool dense charge, what you are trying to avoid is a sick running motor! diesels dont take kindly to air in the high pressure lines!, have you had the same probs i encountered? my mate also has a 99 van that does the same as mine did before the mods
Hello,
well the "Irschenberg" isn't a monster in attitude but a b*stard with a continuing raise cuppled with curves. So the "thin" air above is not realy a problem :wink:
You've asked if i had same problems like you had. Mmmh can't realy tell, if i loose a cylinder when i am allready with about 3500 rmp on the way and just feel a leak of power under the throttle i think i could not tell it is exactly only running on 3 feet at the moment.
Anyway i will change the leaking tube no matter if it showed up or not, at least to prevent of any upcoming trouble.
Greetings
Josef
Josef M.
Postby madmark » Fri May 27, 2005 3:54 am
josef dont forget to tell us how you get and and if it works?????? :D
won't
Postby Josef M. » Fri May 27, 2005 8:00 pm
madmark wrote:josef dont forget to tell us how you get and and if it works?????? :D
I will not forget but first i have to get the parts and manage the time to
work on it. It's our only daily car we have and its often on the way :wink:
Greetings
Josef
Josef M.
