MrMPuk wrote:I don't think he was crowbaring the seat Fred.
I know. I said that's what I had to do to get the tipper's seat moving!
MarkM wrote: A pillar which I don't think can be cut and welded as it is extremely structual. Drivers doors can be distorted and the door seal can also be gone making you think it is leaking at the speaker, I might be premature but I think you have bought a pup
Luke wrote:![]()
you have no faith mark
pritty much anything can be welded - even made stronger with either thicker sheet or added metal, say add some box inside the panel, you should see the work i have done to my mk1 escort, most of the inner wings were fibreglass and newspaper
fair enough markMarkM wrote:Luke wrote:![]()
I do have faith but in a real good welder, which isn't me and the logical areas for this leak is to look where I and others have suggested, it is an assumption but since this new Transit owner appears to be going in cirlces I doubt they will have the skills to weld something as major as the A pillar, welding a floor panel or a plate on the chassis etc is ok if there is some heat deformation but not on such a critical area, a distorted A pillar will mean even more leaks down the line. As already noted elsewhere the screen removal to refit is not a job for the faint hearted as it can often mean a new screen is needed, with a incorrect aligned A pillar you think this is going to go well?
