hi i have a 51 reg swb transit van when i indicate and press the break my indicator speeds up and reverse lights come on when the break is released everything is fine it only seams to happen when i break can anyone help.thanks jamie
Get someone to look at the lights, switch on sides, rear fogs and hazards. Then apply the brakes. Look at which side goes bananas, that is the one with the earth problem. Take out the bulb holder and disconnect the wiring plug. Look for white corrosion on the earth tag. Clean all the connections and you should be fine
Expert burns receiver. Bodger Extraordinaire!! Old Fords never die, however, mine are on life support Fallen in love/hate with Mk6s
