mk6 fwd disc removel
Postby minty0_10 » Sun Dec 20, 2009 12:05 pm
need to change the disc and pads had a look through older posts but can find anything to full explain the job from beginning to end?
what tools are needed are the calliper pistons wind in or push in?
thanks
tweek tweek fiddle fiddle tweek fiddle bang............. bugger
www.southwalestrailriders.com
minty0_10
Re: mk6 fwd disc removel
Postby Dan T » Sun Dec 20, 2009 12:23 pm
There is a 'how to' for a rwd, only difference is you have the driveshaft in the way.
The pistons push back.
Dan T
Postby winterheating » Sun Dec 20, 2009 2:25 pm
dan wheres your how to on the fwd gear selector :?: i couldnt find it :?:
winterheating
Postby Dan T » Sun Dec 20, 2009 2:35 pm
winterheating wrote:dan wheres your how to on the fwd gear selector :?: i couldnt find it :?:
It's on the fordtransit.org part of the site http://fordtransit.org/articles/suspension/drive-train/removal-repair-and-installation-mk6-fwd-gear-selector
I'll need to get Luke to put into the 'how to' section.
I'm also going to try and update the article too, with full strip down instructions and pictures (after i've done another one).
Dan T
