psv-hgv-flt wrote:what year and miles she done, as if there is a lot of brown sh*t in pipes matrix might be blocked. dissconect pipes and put hot steamcleaner through. is it blowing through the rear low vent cold.?? or no air at all. duz valve move by hand, and are you sure you are not feeling the heat up to that point.
02 plate 205k tidy allround cond. blows cold through rear low vent. the white valve that operates the internal flaps moves by hand. (was disconnected when i removed cover, so plugged it in and it just clicks slowly so new one of them needed...high miles is still high miles.
good job i dont mind getting my hands dirty once in a while
