FORD TRANSIT HALF SHAFT SEAL
Postby rosco2009 » Thu Jan 07, 2010 8:26 pm
Have ford transit 53 plate mwb rwd 90 350 td back seal on half shaft has went, oil all over brake shoes etc mechanic has taken wheel off, drum off, shoes etc half shaft wouldnt come out was told too take axle centre coverplate off has done this taken out large pin on axle cloggs was then told too take off locking circlip off end of half sha :D ft but cannot get this off is there something else needing done or special tool.
Please help as need my van back.
rosco2009
Re: FORD TRANSIT HALF SHAFT SEAL
Postby DEAN MACHINE » Thu Jan 07, 2010 8:41 pm
rosco2009 wrote:Have ford transit 53 plate mwb rwd 90 350 td back seal on half shaft has went, oil all over brake shoes etc mechanic has taken wheel off, drum off, shoes etc half shaft wouldnt come out was told too take axle centre coverplate off has done this taken out large pin on axle cloggs was then told too take off locking circlip off end of half sha :D ft but cannot get this off is there something else needing done or special tool.
have you got ABS ? if so take the sensor off and the shaft will push in far enough to get the clip off
DEAN MACHINE
Postby angeleye » Thu Jan 07, 2010 8:50 pm
+1 yes push shaft towards centre of axel, you should be able to get snap ring off
angeleye
Postby rosco2009 » Thu Jan 07, 2010 9:18 pm
Yes abs fitted new to forum so do not know if I am doing this correctly to reply.
Appreciate answers is the abs sensor easy to come off easily damaged and if damaged expensive to replace.
Thanks Ross
rosco2009
Postby DEAN MACHINE » Thu Jan 07, 2010 9:34 pm
rosco2009 wrote:Yes abs fitted new to forum so do not know if I am doing this correctly to reply.
Thanks Ross
its just one little bolt takes the sensor off , sometimes if the bolts rusty can be difficult to get off without snapping it cause its only a 6mm thread i think so spray a bit of wd40 on the bolt , but take it out and the sensor will come off,
DEAN MACHINE
