RE 2002 KEYS LOCKED INSIDE VAN
Postby domkel » Mon Jan 18, 2010 11:25 pm
Hi all i hope someone can help!, i have managed to lock my keys in the van, don't ask. The van is locked and i cannot get it open as keys are inside. How can i open van it is a 2002 transit, if i disconnect battery will this disable central locking?
Really some help thanks
domkel
Re: RE 2002 KEYS LOCKED INSIDE VAN
Postby MrMPuk » Mon Jan 18, 2010 11:31 pm
domkel wrote:if i disconnect battery will this disable central locking?
No and the battery's under the seat anyway. Locksmith or smash a window.
Postby ukluke » Mon Jan 18, 2010 11:31 pm
You can't disconect the battery, you don't have the key's to open the door or bonnet :wink:
ukluke
Postby jolly olly » Mon Jan 18, 2010 11:34 pm
Do you have breakdown recovery if so check to see if it covers this, or call an auto locksmith out and he should be able to get you in quickly as this sort of info will not be posted on an open forum. Or as the van should not be dead locked do you have window cover on your insurance?
Life is not a dress rehearsal
jolly olly
Postby domkel » Mon Jan 18, 2010 11:39 pm
Thanks for the replies, i do have a spare key but there is a problem with the lock and it wont open the door, the key with the fob is in the van and it normally works but i cant get into it! if you know what i mean. Thanks
domkel
Postby jolly olly » Mon Jan 18, 2010 11:41 pm
Is the lock damaged or is the key badly worn?
jolly olly
Postby domkel » Mon Jan 18, 2010 11:43 pm
jolly olly wrote:Is the lock damaged or is the key badly worn?
there is something wrong with the lock but the fob always opens it
domkel
Postby jolly olly » Mon Jan 18, 2010 11:51 pm
It might be best to check for windscreen cover on your insurance, if not a local windscreen fitter and phone then first to see which is the cheapest window to break, as you van should not be double locked unless you locked it by the key which sounds like you will not have done, then you can open only the front doors by the handle, but have you locked the keys in the back and do you have a bulk head fitted?
jolly olly
Postby WINDSCREENGUY » Tue Jan 19, 2010 5:09 am
door glass is the cheapest to break :)
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby Guy88 » Tue Jan 19, 2010 2:49 pm
pull quarter light out :idea:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby WINDSCREENGUY » Tue Jan 19, 2010 3:02 pm
and it would help if we knew where you are the world
WINDSCREENGUY
Postby CJ-Entertainment » Tue Jan 19, 2010 7:29 pm
Did you manage to get it?
CJ Entertainment
Your Professional DJ Service
0114 2499669 - 07892619432
CJ-Entertainment
