transit tourneo
transit tourneo
Postby adts » Thu Jan 28, 2010 12:42 pm
hi all, need some help i have a 03 plate transit tourneo glx and the problem im having is the rear heater only blows cold air has anyone got any ideas to why? does the rear heater have its own heater matrix and if so could it be blocked? hope you can help me because im sick of having cold air blowing onto the back of my next. many thanks scott
adts
Re: transit tourneo
Postby Timbo » Thu Jan 28, 2010 9:13 pm
Check under the N/S rear corner, there should be four rubber hoses going up into the van. The two larger ones are for the rear heater, are they getting hot ? If not then you need to get the water flow sorted by flushing and bleeding any air out.
Where is the cold air coming from ? Normally it comes from roof vents if temp control is set to cold and from the side vents if set to hot.
If you set it to hot and the air is still coming from roof vents then the actuator that controls the air flow is spooned - there is usually a clicking noise from the actuator as the plastic gears slip. The actuator lives in the heater/fan box at the rear and ,aparently, it is fairly common for them to fail.
Timbo
Re: transit tourneo
Postby psv-hgv-flt » Thu Jan 28, 2010 9:53 pm
Timbo wrote:Check under the N/S rear corner, there should be four rubber hoses going up into the van. The two larger ones are for the rear heater, are they getting hot ? If not then you need to get the water flow sorted by flushing and bleeding any air out.
steper motor. also check water shut-off valve. a pic hear
:wink:
psv-hgv-flt
Re: transit tourneo
Postby adts » Fri Jan 29, 2010 10:49 am
thanks mate will check all that outthis weekend, and yes the air only comes through the roof vents.
adts
