N reg 2.5d Transit. HG Change
Re: N reg 2.5d Transit. HG Change
Postby MinorMatt » Fri Feb 12, 2010 11:26 pm
There is a dowel at each end. Like PSV says be careful of the injector tips, or if they want to come out remove em
Postby paul_elwell » Fri Feb 12, 2010 11:35 pm
Forgot to remove the bolt that holds the timing cover to the head
All loose now, backs not great so will await my mate to give me a chip lifting it
paul_elwell
Postby MinorMatt » Fri Feb 12, 2010 11:41 pm
Good plan, you dont want to be dragging the head over the new gasket either so get him to give you hand putting it back (a lot easier with 2 people)
Postby paul_elwell » Fri Feb 12, 2010 11:47 pm
Had a burst of energy and removed it
Happy days
Will re build in morning
paul_elwell
Postby paul_elwell » Fri Feb 12, 2010 11:48 pm
psv-hgv-flt wrote:re do the valve clearance's and lightly oil the threds and tops. o and tight um a bit more. (with a scaff pole) :lol: :lol:
Any ideas what valve clearences should be?
N reg van should it make any difference
paul_elwell
Postby MinorMatt » Fri Feb 12, 2010 11:55 pm
