central locking locks and unlocks
Postby elongcourier » Fri Feb 12, 2010 10:01 pm
hi i have a 2004 ford transit jumbo 90bhp the other day i went to lock the van and with my remote as normal and it locked then straight away it unlocked now thats all it does it wont lock ive tried using the key same thing happens. any help with this would be brilliant as i cant lock my van and its going to get pinched thanks
elongcourier
Re: central locking locks and unlocks
Postby ABBANDON » Fri Feb 12, 2010 10:32 pm
Check the wiring harness in the offside rear door this is commonly caused by a broken earth wire there or sometimes by the pin switches on the side loading door, one way or other the central locking thinks a door isn't shut.
ABBANDON
Postby MinorMatt » Fri Feb 12, 2010 10:47 pm
Go round and open and close each door and try again
Postby angeleye » Fri Feb 12, 2010 11:03 pm
ABBANDON wrote:Check the wiring harness in the offside rear door this is commonly caused by a broken earth wire there or sometimes by the pin switches on the side loading door, one way or other the central locking thinks a door isn't shut.
X2
kinks in the rear door harness will do it ,(broken wires in harness) they get trapped when shutting doors, always feed harness back in when shutting rear doors dont just slam them.
angeleye
Postby elongcourier » Sat Feb 13, 2010 9:36 am
thanks will try that today cheers :D
elongcourier
Postby elongcourier » Sat Feb 13, 2010 11:36 am
hi had a look at the wiring harness on the offside rear door most of the wires are cut the problem i now have is which ones go together anyone no where i can get a wiring diagram from cheers
elongcourier
Postby trigger » Sat Feb 13, 2010 12:02 pm
Who cut the wires or did they get cut by being trapped in the door?
Mk5 Transit the daddy
trigger
Postby AlanN » Sat Feb 13, 2010 1:42 pm
There are some little steel Shields available now to stop crooks cutting the wires in the rear doors and opening them
Postby angeleye » Sat Feb 13, 2010 7:15 pm
sounds like you have been visited by the local scumbags
angeleye
