normanbutler wrote:hi ,i have a oil leak am not mecanically minded,idont even no what the engine part is called ,but as you look under ,stomach down straight in front of me, is a roundthing with 4 bolts the oil is leaking out of it ,right next to it is like a square box with metal fins ,av gotta get amanualam thinking a gasket has blown ,help me if you can thanks from no nothing norman
