by MinorMatt » Sat Apr 24, 2010 3:28 pm
Depends on the year
If both vans have a 3 wire multiplug on the back of the injection pump it would work if you swap the ignition barrel, the pats module and the rim module (bit the wires lead to behind the big steel plate) on the back of the injection pump.
If both injection pumps dont have multiplugs then just swapping the pats module and the ignition barrel will work.
If one has a multiplug and one doesnt you would have to swap the whole dash/underbonnet loom from the donor in to your current van
