egr removal on 2.5 td di
Postby MONSTER 0NE » Tue Apr 20, 2010 7:00 pm
Hi guys
As some of you may know im fitting the 100ps td engine out of my old van which had all the epic egr stuff, my question is can I get away with removing all of the egr stuff as im using the bosch pump manual pump ? eg the egr valve itself and the other butterfly body and connect the pipe for the intercooler straight to the turbo, as it will make my life plumbing up the intercooler a lot easier and hopefully gain a few extra bhp. Hopefully that makes sense, I can take some pics of the bit im on about if it helps.
Cheers Andrew
MONSTER 0NE
Re: egr removal on 2.5 td di
Postby ake » Tue Apr 20, 2010 8:27 pm
Yes
Postby AndyG » Tue Apr 20, 2010 10:34 pm
As AKE said and any bits (like the butterfly body) you don't want/need should be binned into the back of my van :wink:
Postby trigger » Tue Apr 20, 2010 10:46 pm
Andyg wrote:As AKE said and any bits (like the butterfly body) you don't want/need should be binned into the back of my van :wink:
What do you want them for Andy? :? they would be better off in my scrap trailer :lol:
Mk5 Transit the daddy
trigger
Postby AndyG » Tue Apr 20, 2010 10:55 pm
It may have escaped your attention, but mine is an EPIC, as it left the factory :!: That throttle body butterfly pivot can wear and cause problems, so could have one rebushed and ready to swap out :wink:
Postby trigger » Tue Apr 20, 2010 11:17 pm
So you still use the EGR then Andy, how come when everyone else removes or blocks theirs off? :?
trigger
Postby AndyG » Tue Apr 20, 2010 11:30 pm
I fitted a lovely brand new one (for the first and only time) and now my engine warning lamp goes out immediately, like it should :D
If I was to remove it from the circuit, the ECU would log a fault and not only will the engine lamp take 5 seconds to go out (to indicate a fault), but apparently will stop you from carrying out functions like "leakback" trim etc... :wink:
Postby MONSTER 0NE » Wed Apr 21, 2010 12:07 am
Well I better find a nice piece of steel to block of the egr valve mount on the exhaust manifold then, and start working how to run the intercooler pipes I need to run, mind you need to find a decent large intercooler first :lol: .
Andy you should know that I give you 1st dibs on any epic bits I have, I will keep hold of them till we meet at a show.
MONSTER 0NE
Postby MONSTER 0NE » Tue Apr 27, 2010 4:18 pm
Well thanks to darkbluevanman I have a nice laser cut egr blanking plate for free, so thanks again mate :D
MONSTER 0NE
