changing discs
changing discs
Postby ginta » Fri May 14, 2010 2:48 pm
Hi All
I have a 03 2ltr Transit front wheel drive, i need to change the front discs, i stripped the callipers off and removed the drive shaft nut, i also removed the five bolts holding the disc onto the hub. I could not get the hub off, there is 5 holes through the hub with what looks like bolts behind the disc, DO these 5 bolts need to be removed and do you need a special tool??? Many thanks G
ginta
Re: changing discs
Postby MrMPuk » Fri May 14, 2010 3:01 pm
Think there's a how to for this exact job.
Re: changing discs
Postby ginta » Fri May 14, 2010 3:34 pm
what is a how???
ginta
Re: changing discs
Postby Nadjenka » Fri May 14, 2010 3:56 pm
MrMPuk means "Technical how to" section, look there, there is loads of information. I can't see FWD "How to" thread, maybe you could do one? :wink: There is "How to" for RWD tho, perhaps that will help you a bit? :? :arrow: http://fordtransit.org/forum/viewtopic.php?f=18&t=32015#p297181
Nadjenka
Re: changing discs
Postby angeleye » Fri May 14, 2010 6:56 pm
Nadjenka wrote:MrMPuk means "Technical how to" section, look there, there is loads of information. I can't see FWD "How to" thread, maybe you could do one? :wink: There is "How to" for RWD tho, perhaps that will help you a bit? :? :arrow: http://fordtransit.org/forum/viewtopic.php?f=18&t=32015#p297181
its basicly the same
angeleye
Re: changing discs
Postby ginta » Sat May 15, 2010 9:09 am
Thanks for that, it looks more or less the same except mine looks like bolts instead of torx’s I will find out if I need a special socket and post it.
G
ginta
