cranking voltage
cranking voltage
Postby scottyboy247 » Tue May 18, 2010 4:04 pm
hi i have a transit 2.4 rwd, pannel van 2004 reg 125 bhp 330 white.
what should be the cranking voltage read ? mine is 9.2 volts
scottyboy247
Re: cranking voltage
Postby bazw » Tue May 18, 2010 4:20 pm
13.2 + i think :(
what is it at rest ?
350L Series 56 plate
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby MrMPuk » Tue May 18, 2010 4:22 pm
Don't know what fault you have as you don't say but my guess is your van is turning over slowly, probably due to the DMF breaking up and clogging the starter.
Postby MrMPuk » Tue May 18, 2010 4:23 pm
bazw wrote:13.2 + i think :(
Something wrong if you're getting that while cranking!
Postby bazw » Tue May 18, 2010 4:59 pm
thats why the "i think " lol
2.4 duratorq 115 ps
A.R. 4.27
bazw
Postby SirKit Breaker » Tue May 18, 2010 9:49 pm
What is the battery voltage when nothing is running? A good battery should be around 11.5 to 12.5 volts, this will rise to about 13 when charging.
If it is dropping to 9 volts when cranking it sounds like it has lost a cell, does it smell eggy, or does it give off steam when you try to crank it over? Is it getting hot. I would take the battery to a garage and get it discharge tested this will confirm if you have a good battery or not. Before getting into paying out any money check all the battery leads and connections including engine earth strap, if anything is even slightly amiss in this department then you will have no end of problems trying to turn the engine.
Cheers..........Howard
GREAT BRITAIN LOVE IT OR LEAVE IT.
SirKit Breaker
Postby MrMPuk » Tue May 18, 2010 9:53 pm
SirKit Breaker wrote:What is the battery voltage when nothing is running? A good battery should be around 11.5 to 12.5 volts, this will rise to about 13 when charging.
:roll:
Cranking voltages = http://www.tpub.com/content/constructio ... 050_92.htm
Battery voltages = http://www.batteryuniversity.com/partone-13.htm
Pretty much as I said in my first post.
Postby SirKit Breaker » Wed May 19, 2010 5:33 pm
Not disagreeing with you MrM, as you are far more knowledgeable than me with transits. But its always worth a look at the basics before forking out any of the hard earned in my opinion. :)
Cheers............Howard
SirKit Breaker
Postby MrMPuk » Wed May 19, 2010 5:37 pm
SirKit Breaker wrote:Not disagreeing with you MrM, as you are far more knowledgeable than me with transits. But its always worth a look at the basics before forking out any of the hard earned in my opinion. :)
Couldn't agree more but that's hard to do with duff information, that's why I posted the links showing correct voltages.
Postby scottyboy247 » Thu May 20, 2010 10:09 am
high thanks for all your replys,
i was having problems with black smoke and it was not starting till third turn of the key,
then it started on the 4th and now on the 1st but its a long turn of the key, when it starts i get gray smoke,
the tester i used says weak but pass on load on charging pass, cranking 9.2,
carnt say if theres an eggy smell as im all tooked up in the van windows shut lol,( need to be with all the smoke )
ill check for smell, will it be a strong smell of eggs, ( is it bad eggs smell ) ?
scottyboy247
Postby jolly olly » Thu May 20, 2010 10:25 am
It might be worth while checking the fluid level in your battery aswell and if you can see the metal finns inside, top it up with distiled water, i did this and it saved me having to buy a battery, when i check my batteries i only check one cell at a time and put the cover back on asap just to be on the safe side.
Life is not a dress rehearsal
jolly olly
Postby MrMPuk » Thu May 20, 2010 11:33 am
Your battery and starter sound fine, the problems are with the engine, hence the smoke.
